adding SOLAR is on my list for sure... It just makes good sense to be able to tap the sun for a battery recharge during the daylight hours when you are camping off the power grid.
We fight the generator run time restrictions just about everywhere we go on the East side of the US and having solar panels sure would be silent running for sure...
Got to keep the battery banks recharged with something... I suspect I too would get excited seeing the "FREE" sun power re-charge my batteries. Since I really require my batteries to always be charged at their 90% charge state before I start using them each evening I would watch my gauges like a hawk until I got the good feeling as is well. Just getting some trickle charge here and there for a couple of hours during the day would eventually do some harm to the batteries I suspect especially if I use the right away. I would want to have at least 10-20AMPS of solar power available so that the battery banks would re-charge in as few hours as it takes during the daylight hours. The ultimate goal would be to get the battery banks to their 90% charge state so that their full performance will be available for that day/night run off of the batteries.
When I short change myself on charging I don't get the battery performance right away. Then When I short change myself again the next charge period I get even less performance. Eventually I start doing damage to my batteries. My success is to always start out each day/night with a good 90% charge state on my battery bank.
I am going to shoot for a 240WATT solar panel system when I finally get to install solar panels just for these reasons... I will want to see my 14.4VDC or slightly more coming from the solar power panel smart mode charger with a good 20AMPS of current available to recharge my battery bank within three hours or close to that time as it takes. Hopefully 20AMPS being available will re-charge at least two of my batteries at a time in around three to four hours. I almost bet I still have to run my generator to top them off before my real heavy battery drain that starts around 8PM each night to make it through the night and still have 12.0VDC showing on the batteries by 8AM the next morning..
My RT14 is very similar to this roof layout and I am hoping I can add a 120WATT Solar Panel on each side of the Fanstatic fan in the front part of the roof and it also appears I may be able to add a third 120WATT Solar Panel just behind the Air Conditioner across the rear of the roof.
![](http://images1.showmethead.com/nlarge/2008_starcraft_13rt_pop_up_toy_hauler_yadkin_county_for_8_400_21127761.jpg)
When I am parked at home it can takes several days to re-charge and won't bother any operations...
Just my observations
Roy Ken
