lanerd's avatar
lanerd
Nov 21, 2016
T-Stats in Class A's
Do some Class A's have a single AC/heat pump thermostat for all the AC's or is there a separate thermostat for each one?
Friend of mine just got a 2004 DSDP and says he only has one t-stat but two AC's.
thanks
Ron
  • wa8yxm's avatar
    wa8yxm
    There are 3 answers but the short answer is YES.. I will explain
    Some have a single thermostat but two temperature sensors. the Thermostat will show two "Zones" one for each sensor, Normally Zone 2 is the rear. This is very common.
    Some Well.. there is no reason you can't have two Thermostats one for each "Zone"
    and finally technically you could have a single stat control multiple units but.. I've never seen it or heard of it.
    Fact: With a Carrier Air V air contioner The A/C has the ability to control the furnace. and my Motor home one of them did.
    Alas, had to replace it... So I got a 20 buck (includes part of the sales tax) "Mercury Free" heat only T-Stat from ACE hardware.. A Switch from Lowes (nice rocker looks good where I put it) and an LED and series resistor from my Junque box
    Switch on, LED on T-Stat controls furnace
    Tested this AM (power fail took out my Electric heaters) and it worked great.. In fact.. I had issues with the Carrier's control of hte furnace.. No so where I mounted the wall stat.. And once I do one tiny touch up, the job will LOOK factory.
  • Chris Bryant wrote:
    Single thermostat, but it uses separate zone with separate sensors, so temps are set per zone.
    This
  • Single thermostat, but it uses separate zone with separate sensors, so temps are set per zone.
  • Only one in my two Winnebago's but you can set each unit as you would like by using the thermostat
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
