Bobbo's avatar
Bobbo
May 18, 2015
The solution to MY sewer smell in the RV
For about a year I have had a sewer smell in my RV when the black tank is 1/2 full or more, or when driving down the road. Over that period I:
1. replaced both AAV's, didn't work.
2. got on the roof and checked to see if a vent pipe had fallen into the tank, it was fine.
3. got on the roof and flushed a lot of water down both vent pipes in case something had plugged the bottom of the vent, didn't work.
4. replaced both AAV's again thinking a plugged vent may have ruined the new AAV, didn't work.
5. and, finally, this winter, I took up the toilet and replaced the seal between it and the floor.
We just got back from our first camping trip (4 nights) after replacing the seal, and had NO sewer smell. It must have been a bad seal all along.
  • Just think of all the $$$$$ you can save on chemicals now.
  • And odors from grey tanks can smell as bad as a black tank.....so when hunting down a 'smell' you check then
    Sorry it took over a year to ID toilet seal
    'P' traps, AAV, tank vents, toilet bowl seal and floor flange seal....normal sources.
    Broken/cracked piping is one of the last items to check
  • Ahh.. That makes sense. Mine doesn't, which is why it was confusing me.
  • Bobbo's avatar
    Bobbo
    The AAV is the Air Admittance Valve under your kitchen and bathroom cabinets that vents the sink drain so the vacuum doesn't suck all of the water out of the trap every time you use the sink. It lets air into the sink drain without letting air (spelled S T I N K) out. It is between the trap and the storage tank.
    The black tank has an AAV because the bathroom sink drains into the black tank.
  • navegator wrote:
    What is a AAV?
    I wish that those that text would let us that are thumb challenged know what they mean
    Air Admittance Valve, which lets air in so the sink will drain.
    I use complete sentences and properly spelled words when I text. TTFN. LMAO.
  • What is a AAV?
    TSMFYK
    navegator
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
