- ncrowleyExplorer IIWe use the Flo Pur RV Pro 10000 water softener. As already stated, it used 2 pounds of ordinary table salt to regenerate. The only issue we have had was with the plastic Y at the outlet port. It broke and we replaced it with a metal one. You flush it after regenerating so there should not be salt that would eat up your drain plug. We put a Y just before the hose goes into the water softener and I get drinking and cooking water there. Some people do not worry about the trace salt in the water. It is the same issue when you use a water softener at home. After we started using the softener, we do not get all the water spots and scale we used to get using the hard water out west.
- calewjohnsonExplorerWe use a Flow Pur water softener and love it. The first couple of times I regened it, I did not ensure the salt was gone and made a gallon of sweet and salty tea...it was a shock to the system. Now, after I regen, I run the cold water until there is no salt taste... Daughter and wife loves the soft water in the shower.
Cale - MTPockets1Explorer
rdhetrick wrote:
. I think this supports what I said, using the words insignificant is doctor talk. Doctors are best at covering their butts, proper use and regeneration and the salt is all washed away.MTPockets1 wrote:
dbbls wrote:
. There is no salt effect in a water softener. Salt is used as the chemical agent which releases the hard minerals collected during use. After regenerating with salt, any salt residue is rinsed and gone=no salt. Doctor needs to stick to the no salt part which he is qualified, but the softener doesn't contain salt except while regenerating. Don't use water until regen is complete.
I considered a softener but i am on a restricted salt diet. Doctor said not to get one.
Perhaps you should stick to commenting on what you are qualified to answer. Water softeners do in fact add a small amount of sodium during operation - it is this ion exchange that makes them work. During operation, the resin captures a calcium or magnesium ion and releases a sodium ion. During the regeneration process, it swaps back the captured calcium/magnesium ion with a sodium ion.
Granted, it is a small amount, but depending on the extent a person is trying to limit salt intake, it might be significant.
Mayo Clinic FAQ - blkdodgeExplorer
Old-Biscuit wrote:
blkdodge wrote:
I also have a water softener
I have noticed that the water heater Anode Rod will get eatin up faster because of the salt.
Just something else to watch out for.
You could swap to an aluminum anode rod..........but it may not protect as well when using softener
I do have an aluminum anode rod and have to replace it roughly every 12 months. - Old-BiscuitExplorer III
You could swap to an aluminum anode rod..........but it may not protect as well when using softener - 2oldmanExplorer II
dbbls wrote:
That must be a very strict diet. You don't have to drink it.
I considered a softener but i am on a restricted salt diet. Doctor said not to get one. - Clay_LExplorerI have the FloPur Mark 8000.
Cost is $220 and includes shipping if bought from the site above. Regeneration is done with a box of common table salt.
It is similar to others like the "On-The-Go" water softener which is the one Camping World sells I believe.
Both are 8000 grain units which means they will last longer without requiring regeneration. Some folks use "Water Sticks" but the biggest one of those I have seen is only 1500 grains.
In AZ where we spend most of the winter the water hardness is about 50 grains per gallon. That means that an 8000 grain unit will soften about 160 gallons before needing to be regenerated. Since we use about 13 gallons of water per day we have to regenerate every 12 days or so.
In our home in CO we have a water hardness of 20 GPG, there the softener will last about a month. It is possible to regenerate using potassium chloride if sodium is an issue. - blkdodgeExplorerI also have a water softener
Just something else to watch out for. - rdhetrickExplorer
Mayo Clinic FAQ - MTPockets1Explorer
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 09, 2025
