scottandgaye's avatar
scottandgaye
Tiki Torch - BATERY Powered, NOT Solar
So, I am looking for a few (4ish) tiki torches that are battery powered and NOT solar. Where we usually go is covered in trees and the solar ones never recharge.
Does anyone know of true battery operated tiki torches that do not rely on solar? An actual tiki torch with a real flame is out, due to the requirements of the campground.
Thanks in advance! I look forward to hearing what folks have to say.
Scott
  • wa8yxm's avatar
    wa8yxm
    scottandgaye wrote:
    Side note: I'm a EE for the last 40 years. Instead of a response like "cool" or " that's great", I got a "how come you didn't know that?". You just can't win.
    Scott
    Well you'd not know that less you opened one up.. I'm not a professional EE (though that was the plan 50+ years ago) I'm a Ham Radio Operator. We Tinker so naturally I opened mine up... All the ones I opened had either AA or AAA batteries and I have that handy dandy 4 bay charger.
    NO reason to sever the wires.. it won't hurt the batteries to recharge a little bit and due to slightly different voltages they might not recharge at all. YOu do need to pop in new batteries every so often however if you use regular ones or they leak and damage (But you know that)
  • opnspaces wrote:
    I just noticed those rechargeable tiki's at Lowes the other day. Do you like them? Do they look somewhat realistic? I have an embankment in my yard that I always wanted to put Tiki's on. But don't like the idea of an open flame in that location. And Amazon only has short LED tiki's on plastic poles.
    Yea, the are not bad. They don't put out a ton of light (just 1 AA battery), but they do they do give the area a nice soft light pattern. Our problem was that where we put them, it was always in shade and never recharged. These have an on/off switch, so I can left them out there and just turn them off when we go in for the night. Hope that helps!
    Scott
  • I just noticed those rechargeable tiki's at Lowes the other day. Do you like them? Do they look somewhat realistic? I have an embankment in my yard that I always wanted to put Tiki's on. But don't like the idea of an open flame in that location. And Amazon only has short LED tiki's on plastic poles.
  • wa8yxm wrote:
    The solar ones are battery powered usually AA or AAA and you can recharge them with an external charger off line (120vac)
    Here is one such charger
    Xtar charger
    And here is another.. I have th4 4 bay model
    Another Xtra Charger
    Well, I just took one of the ones that we bought at Lowes's last year apart (the top just screws off) and saw that it was nothing more than a single rechargeable AA battery! I replaced it with a standard AA battery and severed the wires from the solar panel down to the control board (don't want to charge a non-rechargeable battery).
    Scott
  • Thanks for the info. I just assumed that it used some sort of soldered in battery pack. I will look at those. I appreciate it!
  • wa8yxm's avatar
    wa8yxm
    Xtar charger
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
