mrekim's avatar
mrekim
Tire Failure
I have these photos of a couple of different tire problems. I'm just offering them up in hopes they will help people when inspecting their tires as part of prepping for the season:
This can happen on the inside or the outside. Sometimes you can feel the bubble forming before you can see it.:
The tire guy told me this was probably a broken belt. See how the radial tire tread on the right is round vs the ok one on the left that is flat. This was discovered when looking for bubbles. I could feel very small "ripples" in the side of the tire. The ripples were too small to catch from just looking.
  • The first is what is called a ply separation...at a high stress area(the Crown) that transition area between body plies and belts. Any separation can occur for various reasons...scrub a curb, a improper repairs, over flex form under-inflation, bead damage from R&Rs,impacts breaks but rarely nowadays from Mfg defects.
    In modern terms there is no such thing as a slipped belt, which could only have happened before the curing process as it was being loaded into the matrice. Those being the old clamshell molds/matrices for which now everyone is using the segmentated molds.
    The second would go down as a tread separation...here the same rules apply with a caveat...this could be all of the above and or a manufacturing or material issue.
  • Good thread and pictures! :)
    You will probably be interested in this thread by member JBarca that details, with pictures like you did, his experience with somewhat the same tire failure.
    Barney
  • The pic of the broken/separated belt is a good one. I had never encountered it before last year when my truck tire did this. If this happens it will not ride well at all and you will know something is wrong. I stopped twice before I noticed the crown in the tire tread.
  • Nice post and good time for it. I often forget that the inside of a tire deserves inspection as much as the outside.
    Be a great sticky if a post was created to show all the problems can have...maybe I will do some research and follow up.
    Great reminder!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,109 PostsLatest Activity: Feb 07, 2025
