BurbMan wrote:
Airstreamer67 wrote:
I got a piece of thin plastic pipe that fits over the rubber valve stem, cut it to size to allow the sending unit to screw fully on the valve stem, modified the bottom of the plastic pipe with a Drimel to fit the curve of my wheel, and placed it over the rubber valve stem. It keeps the PressurePro sender from flexing the stem, thus making it "act" like a steel valve stem.
You should sell that idea to PressurePro, they can package them with their product.
The reason I made the valve stem cover was my tire dealer didn't have the size of steel valve my travel trailer needed. Most steel valves go on truck tires, and my rims are a different size and configuration. He said he could try ordering them, but I was going on the road and didn't have time to wait.
So, I went to Ace and bought a 10-foot length of half-inch plastic pipe, a Schedule Something-or-Other which had thin walls and was lighter.
I used a pipe cutter to cut the needed length to fit my particular rubber valve stem and used the Drimmel to carve the shape needed for the bottom of the pipe to fit my particular wheel. The length was cut so that the PressurePro sending unit can screw fully on.
It took maybe 10-20 minutes to cut and shape the first one, and each subsequent one much quicker since the cut dimensions and shape are identical for each wheel.
With the pipe in place, the stem is held taut by the screwed-down sending unit and cannot flex.
Now I got about 9.5 feet of pipe left, which I figure should be good for another 115 tires.
