- Bama2nzExplorerI have had 2 blowouts on same left rear tire. Within 200 miles of each other. Of course they are China bombs "as folks call them ". I'm putting on 4 Michelin LT 245/75R16 E XPS Ribs tomorrow. Plus the 507 tst tpms. Hope this takes care of it.
- MrWizardModeratorMoved from technology
- LynnmorExplorerHow big are the road stones where you might travel?
- I read the clearance between tires should be 1" minimum.
What is the concern in your situation? - wa8yxmExplorer IIIThere is and it may vary from brand of tire and size of tire to brand and size. but generally take a look at the X-Chock products (you can see them at RV Stores)
This is basically a sizzors jack that goes between the front and rear tire on a dual axle Trailer.. If there's room to put it in and "Expand" it so as to lock the axles together.. you are good. - MitchF150Explorer IIIAs long as they aren't touching, that should work... ;)
But, in general, it seems that leaving at least a couple of inches is the min..
Then, I've seen what looks like 12-18" between the tandem axle tires..
Good luck!
Mitch
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 22, 2025
