Larrysr1957's avatar
Larrysr1957
Towing a 2 wheel drive automatic transmission
If I’m correct you can’t tow a 2 Wheel Dr. automatic transmission because the transmission would overheat but my question is, can’t I put the truck in neutral with the engine running and pull it, that way with the engine running it will circulate the transmission fluid keeping the transmission cool. Are there any mechanical reasons that I cannot do this. And no the gear shift cannot jump into reverse. I can get a electric brake that will operate with the power brake active.
