Champ198
Aug 12, 2016Explorer
Trailer Brakes - How hot is TOO hot?
Hi everyone,
I have a new rig (see sig). It weighs 12,130 lbs unloaded and we may have 400lbs loaded in it so we're not close to overloaded. I've been worried because I have the gain set to 10 (max) on heavy electric (RAM has 4 settings: light electric, heavy electric, light hydraulic over electric and heavy hydraulic over electric) and have the transmission braking and exhaust brake working.
The trailer seems to push the truck when stopping (like when someone pulls out in front of you or the light changes on you and you have to stop rapidly) I got to the campground last night and I can hear the electric brakes engaging as I press the truck brake so I know they're working.
Of concern was that the trailer brakes were super hot as I could feel the heat radiating from the wheels. Never had a trailer that had that much heat coming out from the wheels. I did not check temp. They are extremely hot every trip.
I have the Lippert 7k lb axles with drum brakes on this trailer. Are the brakes simply too weak to stop the load?
Looking for feedback. Thanks!
