TravelByJeep
Aug 09, 2016Explorer
nevadanick wrote:
Have you had to add brake fluid before you installed new brakes ? If so when you installed the new brakes the master cyclinder would now be over full and when the fluid gets hot it expands and locks the brakes.
The master cylinder does not get hot and is not used for an expansion reservoir. Fluid squeezed out of the calipers does however get forced back into the reservoir as long as it is not overfilled, if it is it will either leak out at the lid/cap or you will not be able to compress the calipers.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
