CHD_Dad's avatar
CHD_Dad
TT Tire advice - going from 14" to 15" - or??
Background - 32' TT (In sig line) / 6700# fully loaded as per CAT / Tandem axle towards middle of TT / 14" alloy rims.
So several years ago I had a blow out with a no-name OEM TT tire. Changing that on the side of the road with 80mph traffic going by while it was 95+ degrees sucked to say the least.
Bought new camper in 2012. Drove on OEM tires two trips and then swapped them out for current tires - Maxxis M8008 Load Range C in the OEM 205/75-14 size. They are about 2-1/2 years old now.
Trip home two weeks ago and - blowout! Now since the first blowout I have been anal about my tires. They are covered when not being used. I check tire pressure before all trips. I keep my speed at 65mph 90% of the time (may briefly increase to pass somebody). I check them for tread wear, sidewall wear, etc. No clue why it blew out but it did and not in a nice way. I have very minor damage to the wheel well of my TT but it is damage. I cant remember ever curbing it or hitting anything with it. Other tires all look great. The tire that blew look great with deep tread, no cracks, no bulges, nothing.
So now what do I do? Serious question! The only D range 14" tire I can find are Kumhos and I am fine with trying them out. I think Goodyear still makes a bia sply D as well for U Haul trailer use. I looked into them before but was worried about going bias ply.
Other option I have is going to a 15" rim but what exactly will that help? What am I missing to make my tires last longer? This is getting to be a pain and expensive if I need to replace tires every 2 years!! I've got wife, 3 kids and 2 dogs I am hauling around so safety is #1.
As for clearance I dont have much. It is a low trailer with closely spaced axles.
Stock - 205/75-14 C
In between tires - 5 inches
From top of tire to bottom of TT - 3.5"
I think I "may" get away with a 15" tire but it could be tight since they dont make a lower profile 15" that I am aware of that has the load carrying capacity needed to keep the OD the same.
Right now I have only 300# of extra carrying capacity total or a measly 75# per tire. I was thinking going to a D may help things run cooler and safer.
Advice? We have a big trip through the NC mountains in a couple months and the last thing I want to worry about is tires!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
