โJun-21-2015 06:29 PM
โJun-28-2015 11:54 AM
โJun-28-2015 10:48 AM
B.O. Plenty wrote:Turtle n Peeps wrote:Totally agree! How can eliminating the 10% alcohol give you an additional 6 mpg on the highway..I'm gonna have to throw the BS flag on that one.
E free gas will give you about 4 to 5% difference in mileage.
If anybody tells you appreciably more their math is wrong or their testing is flawed.
E gas will always give you more power because of the O2 and cooling effect it give your engine.
B.O.
โJun-28-2015 10:14 AM
โJun-27-2015 07:37 PM
โJun-26-2015 05:36 AM
โJun-26-2015 05:07 AM
tatest wrote:
Here it might cost 10 cents to 40 cents more per gallon, at 30 cents it doesn't save me money in improved MPG. So I don't seek out the stations that have it. Lately about $2.40 for E10 or less, $2.70 for no ethanol. One of my vehicles is flex fuel, and I actually save money running E85 if the price is at least 60 cents lower, but I lately been finding that only in a couple of corn belt states that totally forego road taxes on E85. The Federal subsidy for ethanol has been shrinking, and may not much longer even cover the higher production costs.
I do buy it for my small engines, but all of those together don't use more than four gallons a year, so at twice as much it might be worth it to avoid equipment trouble on the tiny two-strokes.
โJun-25-2015 09:29 PM
โJun-25-2015 08:50 PM
CavemanCharlie wrote:Where my seasonal site is at in MN they sell boat gas that is E-0.
All the gas in MN is E10. No matter what it says on the pump. If it says otherwise it's just to make you feel better. If you think you are getting better mileage using non-ethanol gas around here then you are just imagining it.
It's like someone taking a drug that they say makes them feel better. When in reality the doctor just gave them a placebo.
โJun-25-2015 05:29 PM
โJun-25-2015 05:13 PM
โJun-25-2015 04:51 PM
โJun-25-2015 06:04 AM
JaxDad wrote:Well that makes a lot of sense, I had not thought about the Octane level being modified.westend wrote:
So let me understand this, there were people who claimed that replacing 10% of their gas with Ethanol resulted in a 15% loss in mileage? This must have been a user calibrated event.
My only real experiment with alcohol and different fuels was driving a late model minivan. I rented this van and used E85 for a few tankfuls (maybe 5). I noticed a 10% loss in mileage compared to E10.
The big problem is water.
Before the transition to Ethanol the oxygenation was handled by the addition of MTBE to gasoline, this mixture does not absorb water in any material amount.
Ethanol on the other hand mixes quite readily with water and is in fact hygroscopic, it very aggressively absorbs water and holds it in suspension until it's saturated and just cannot absorb any more.
Despite very prevalent myths to the contrary, phase separation occurs very quickly under the right conditions, and even under just typical atmospheric conditions occurs in 90 days on average. This is caused by the ethanol just absorbing the humidity out of the air and condensation. If there is actual water present, like in the bottom of a storage tank, the ethanol quickly absorbs it.
At just 0.5% water entrainment reaches the point where the E10 mixture is no longer able to hold the water in solution. At this point the water-laden ethanol starts to fall out of solution and settle down out of the mixture. You would then have a large top layer of nearly pure gasoline, and a much smaller layer of very water-laden ethanol below that, then finally a smaller layer of pure water at the very bottom.
As the ethanol falls out the gasoline loses an important source (the ethanol) of it's octane. If you had this happen, 87 octane fuel would drop to approx. 84 octane.
So now you have a car running on non-oxygenated 84 octane fuel until it gets down to the very wet straight ethanol at the bottom of the tank.
Now this is an extreme example, but it only takes a little water to significantly affect performance.
โJun-25-2015 05:10 AM
โJun-24-2015 10:43 PM
JaxDad wrote:westend wrote:
No one is losing 10% in mileage by using an E10 gas blend.
I have no reason to doubt the OP's results but some of his mileage differences may be due to the intrinsic construction of the engine and it's fuel management accessories and not absolutely due to the addition of alcohol.
Funny that. Gasbuddy.com held a poll on users mileage loses due to using E10 fuel. The largest group responding said they lost between 5% and 10%, the second largest group said they lost between 10% and 15%.
Then from the website of a little magazine called Road & Track I find ".... switch to E10 (gasoline cut 10 percent with ethanol), your mileage will drop. The big question is by how much. The Environmental Protection Agency says E10 lowers mileage approximately 3 percent, which would drop your mileage from 19.6 to 19.0 mpg. Instead you're citing a drop between 10.2 and 15.9 percent, which, while similar to some E10-induced losses we've heard of, does seem large. We typically hear of mileage drops in the 6- to nearly 10-percent range..."
โJun-24-2015 06:46 PM
