Weight Distributing Hitch for 2010 Ford Expedition EL
Roro88
We have a 2017 Aerolite 242BHSL travel trailer and want to tow with our 2010 Ford Expedition EL. Does anyone know what brand and type of Weight Distributing Hitch we should use?
Hitch Weight on trailer is 720 lbs
Dry Weight of trailer is 5510 lbs
Cargo weight is 1090 lbs.
Our Expedition has 600 lb hitch weight and can only tow 6000 lbs. Was told by Ford we needed the weight distribution receiver hitch.
Any help would be greatly appreciated
8 REPLIES 8
APT
You need a WDH for sure. You also should upgrade the transmission cooler if you do not have the HD towing package.
2017 Subaru Outback 3.6R
Hannibal
Etrailer's opinion...
https://www.etrailer.com/question-217136.html
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
Hannibal
I just went from a Reese HP wdh with no sway control to an Equalizer 4 Pt 10k hitch. Works great! For noise, keep the sockets lubed as per Equalizer's instructions. I use marine grease. I went against heaven above and put some grease on the spring bars and L brackets, then wiped off with a rag. Nice and quiet while still offering good sway control "in my humble opinion". We didn't have a sway problem before but it still prevents waggle from passing trucks.
1492
Moderator
Moderator
Roro88
Thanks everyone!
downtheroad
For your trailer....
Equal-i-zer brand hitch
Reece Dual Cam HP hitch
Blue Ox SwayPro
All good.....probably look for 800-1000 lb. bars. This should cover your loaded, trip ready tongue weight.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
samsontdog
I have a 4 point equalizer . It is a great set up.
samsontdog:o:W
Lwiddis
Yes, a WDH would be necessary IMO. I'm happy with my Equal-i-zer. Others are good too. Not only "need" it, you will want it to shift weight back to the TT wheels and forward to the TV's front wheels.
