Zigpep's avatar
Zigpep
Weight questions
Hello, we have a 2004 BT cruiser 5250, it currently has a class 2 hitch with max weight of 3500 lbs. We are setting it up to tow our 2013 manual Jeep Wrangler.
We have weighed both jeep and almost fully loaded rv ( we will be adding food, clothes and 1 more person to the weight of the rv). We used certified scales. Jeep weighs 4040 and rv weighs 12040 and GCWR for the rv is 17550. This puts us at 16,080 plus maybe another 400 max for food, clothes and myself. This puts us at 1000 lbs under. I have looked all thru owners manual of the BT cruiser and can find no tow rating just the GCWR and GVWR. I looked at the owners manual for the E450 v10 and it says we can tow 10,000 lbs. however I have also ran the vin number at the ford site and it says for this specific vehicle we can tow 5900 lbs. We will be towing 4 down so tongue weight should not be an issue.
Questions are 1- does the towing of the jeep add to the rear axle weight, it is at 7780 lbs now and front weighed 4260?
2- is that a normal weight distribution for front and rear axle or have we loaded the trailer poorly? So far on the 2 trips we made without towing a vehicle the handling of the rv was awesome even on twisting mountain roads.
3- we are going to change to a class 3 hitch but will this add significantly to the weight? again it has a class 2 now
4- I know you should try not to overload your vehicle and I am thinking at 1000 lbs under we should still be ok? Most of our driving is in the mountains.
I am making 2 other posts re towing but they are more specific to the tow vehicle and the system we are using.
Thanks zigpep
  • Thanks, I am so excited to be able to tow the jeep. We were looking at the numbers wrong and thought it weighed to much. Part of the pleasure of trips for me is riding along and seeing the sights on the way to our destination.
    thought I was going to be stuck driving behind the rv. I have even checked the front and rear axle weight limits and we are good to go.
    Thanks zigpep
  • 1. Not appreciably. Half the weight of the tow bar, half the weight of the safety chains/cables, and the weight of the "moustache" rock deflector if you use one.
    That said, there may be some dynamic shifting of additional weight on to the rear axle during acceleration, but we do not take that into consideration when towing. The designers took that into consideration when designing the vehicle and coming up with the ratings.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
