All LT and ST tires in the sizes were talking here have a two ply sidewall regardless of ply rating with additional steel belts in the tread.
PLY RATING Tire Rack Load Range/Ply Rating Identification
The load range or ply rating branded on a tire's sidewall helps identify how much load the tire is designed to carry at its industry specified pressure. Passenger tires feature named load ranges while light truck tires use load ranges that ascend in alphabetical order (letters further along in the alphabet identify stronger tires that can withstand higher inflation pressures and carry heavier loads). Before load ranges were adopted, ply ratings and/or the actual number of carcass plies were used to identify the relative strength with higher numeric ratings or plies identifying tires featuring stronger, heavier duty constructions.
Today's load range/ply ratings do not count the actual number of body ply layers used to make up the tire's internal structure, but indicate an equivalent strength compared to early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy-duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric plies, or one steel body ply.
