DSchmidt_2000
Sep 15, 2014Explorer
Will bearing issue heat entire drum or just the hub area?
Have one drum/hub that is uncomfortably hot vs the others being just warm on a tandem axle 4 horse trailer. Not just the hub portion, but also the outer part of the drum on the part the shoes press against is hot.
Given the outside part is as hot as the hub, do I have a bearing problem or a brake problem?
Just going through what it could be in my head and am leaning towards a brake problem. Either way I'm going to dig into it but wanted to know from you all if a person could tell just from where the heat is to know which thing is screwed up.
