walker111's avatar
walker111
winterized to late...... busted faucet question
Hi all.
As title describes I didn't take care of the plumbing in time as I bought my toyhauler the last week of September and.......
When I did get it winterized I found the outside shower leaking. It has the general quick connect in metal. The inside shower is leaking from behind where the shower wall and plate on taps meet.
The kitchen faucet needed me to put new seats and springs in but the hose that threads to the pull out hand faucet has a crack and is leaking there. I found all three problem areas using water first then winterizing and pumping antifreeze.
This error is going to cost a few bucks but my mistake.
Questions. Maybe these will be answered when I pull them apart?
can I buy new cartridge inserts or need new tap assembly on the shower inside and the one outside?
I think I can buy a new hose for the kitchen faucet with crack being in the threaded connector.
Thanks in advance.
Not next year!!!
  • I don't think there is that access that you speak off. I will know more in a few weeks when I tackle this project.
    Thanks.
  • Dick_B wrote:
    Hopefully you can get behind the wall that the shower taps mount to and get a better idea of what is leaking.
    With all the cost cutting that goes into todays trailers, mine has a false vent cover on the wall in hall that hides access to the back of the shower plumbing so one might want to check out for any existing "HIDDEN" access points. BTW I have the same vent on the bottom tub panel to access the tube drain fitting in the bathroom
    Larry
  • Hopefully you can get behind the wall that the shower taps mount to and get a better idea of what is leaking.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
