FIRE_UP
Oct 31, 2014Explorer
UsualSuspect wrote:discovery4us wrote:
I guess the year would help, not sure where my head was (wait don't answer that!). It's a 2004 Chevrolet 2500.
Mine is an 07 Classic. I ran the wiring for the lights from the front bumper, down the drivers side frame to the rear. There is enough room behind the taillights for diodes. I used the BlueOx Diode kit on mine, but any of them will work.
I am thinking you will also need a relay for the brake lights. The relay is installed in the cab, and prevents the brake lights from being triggered by the supplemental braking system. The lights should all be wired off the coach.
I did all the wiring myself, and it took me an afternoon, most of the time was trying to figure out how to twist my body around to be able to get the connections done under the dash for the brake light relay.
If you are in SoCal and close enough you can take a look at how I did mine.
I used to think that ALL vehicles were setup so that the brake lights were activated when the brake pedal was pushed, ignition on or not. But, in all my toads, I've found that many, do not have the brake lights activated by the brake pedal, if the key is OFF.
This is why I asked the OP what year he's planning on towing. On our present toad, the GMC, it DOES NOT ACTIVATE BRAKE LIGHTS when the brakes are applied via our Ready Brake while being towed. But, our previous toad, a 2011 Honda CR-V EX-L, AWD, DID have the brake lights activate when the brake pedal applied, even when the key was/is completely out of the car.
So, just for grins, have the OP push on the brake pedal of his intended toad, with the key in the OFF position, and see if his model/year of truck, does or, does not, activate the brake lights, when the pedal is pushed.
Yep, I ran the wires the same way, all the way back to the left tail light housing area and, there's where I did all the work. As far as the diodes, I used some cheap-o Radio Shack ones. I got the largest they had for about $4.00 for a four pack. They've always worked perfect. But, it's nice that the stock tail lights work great for this part of towing. Good luck.
Scott
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 22, 2025
