- RAS43Explorer III
Have you checked the batteries to be sure they are fully charged? They must be to move most slides.
- QCManNomad III
Did the person who decided the motor needed replacing ever test the slide after the replacement? Have you checked to see if the slide locks were off ( if you have them )? No slide will move if the locks are on.
- RigginaiExplorer
Thanks for the response! Yes, they tested but slideout still not budging. So not really sure if the motor/pump kit was defective in the 1st place. At this point, i just want to have the slideout in, even manually, and we can't even do that so I can take it to a shop.
