mustangglp wrote:
So how do you go about disconnecting the converter:h that would be sweet
the only downfall I can see would be having to go outside and switch the plug to run the generator. I could mount the inverter in the generator compartment right next to the batteries?
Yes get it close as you can to the batteries. I just unplug my converter. When I had a 5th wheel the converter shared a breaker with the outlets. I moved it to its own breaker but my MH already had it on a separate breaker. Some people put an on/off switch on the converters 120V line.
![](https://lh3.googleusercontent.com/-9kb5XO64Xx4/UU-GOnmJhBI/AAAAAAAADyg/lGlhjMtWzKY/s640/Converter04.jpg)
