Texas_Two_Stepp's avatar
Sep 21, 2013
120v Water transfer pump
Do u have a favorite 120v water transfer pump for boondock camping? My 12v
burned. I need a small reliable unit
  • wolfe10 wrote:
    While there are small 120 VAC water pumps available, I agree-- would stick with a 12 VDC pump. That would also give you a spare pump if your primary pump fails.
    We do the same. There is 12VDC available at the rear trailer jack at the back of our rig and I made made up a plug for the pump and just plug it in there. You can by hose bib adapters at any decent home supply (ie Home Depot) that will allow you to connect a hose at the input and output of the pump.
    We use ours as a booster pump when camping in Mexico as usually the water pressure there is less than adequate. It can take hours to fill the tank from some of the gravity feed systems there.
  • While there are small 120 VAC water pumps available, I agree-- would stick with a 12 VDC pump. That would also give you a spare pump if your primary pump fails.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
