KendallP
Jul 27, 2017Explorer
1986 Onan BFA 4 - Starts every time, but runs just 5 sec.
So today I finally got around to pulling the top off the carb, including float, needle and spring. But first I started er' up and ran her for a minute or so. But I didn't want to heat her up before taking it apart, so I shudder' down.
Got 'er all put back together after the clean. Verified everything in it's proper place with photos. Went to start her up and...
1. Ran for a few seconds. Probably running on carb and choke cleaner. Bowl was empty. Probably should have put some gas in the bowl before putting the lid back on.
2. Then wouldn't start forever.
3. Sprayed a little carb and choke cleaner in the air cleaner and got 'er to fire up.
4. Now time after time she will start... run beautifully for about 5 seconds and then shut down.
The weirdest part (to my anyway) is what's going on in the clear fuel filter (fairly new, by the way.) It's only about a third full of gas, which bothers me a bit, but what's weird is... when I hit the start switch, I can see gas flowing into it. But after she fires up, it seems to quit. Then 5 seconds later, she dies.
The fuel filter is sitting intake side up. So there isn't any air flowing down into the fuel pump.
Coach currently on shore power.
I need the generator by morning.
Any thoughts?
Any thoughts?
