bsinmich's avatar
bsinmich
1998 V 10 Trans
I am buying a 1999 Damon Challenger and wondering about the transmission. Is it 4 or 5 speed? Thanks.
  • Should be a 4 speed with OD. Depending on the mfg date of the chassis,an AOD-E or a 4R100.
  • Four speed for sure. No tow/haul mode; all you can do is lock out upper gear(s) if needed (via an overdrive off button and the usual automatic shifting).
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
