Jason2017's avatar
Jason2017
2000 Harney Sedona Wiring Problems
Hi, I have a 2000 Harney Renegade Sedona, I am in need of a wiring diagram and some help if possible?
I bought this rv knowing it needed a little work. When I picked it up it started from the rear panel start button. since getting it home on a low boy, it will only turn over from the push button on the rear panel, but will not start. sounds like its not getting fuel to the motor. Im not sure about the wiring since I do not have the wiring diagram. I do have all the books for everything else if any one is in need. Im also not are if the batteries are hooked up right. thanks for your help. you can use my private email to contact me if you would like.
JasonElderkin@outlook.com
  • I DON'T KNOW IF I EVER THANKED YOU GUYS FOR THE WIRING DIAGRAMS. THANK YOU I REALLY APPRECIATE THEM. ITS UP RUNNING AND FINISHED NOW. THANKS AGAIN FOR THE HELP!
  • Jason
    I have the wiring diagrams and sent you a private email yesterday. Let me know where to send them and I will do it tomorrow.
    Busyguy
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
