โNov-03-2015 03:55 PM
โNov-04-2015 10:24 AM
TWZMYJP wrote:
No, actually one of the side markers at the belt line was also dead, and turned out to have the same issue with +12v on both conductors... That is where I was able to find the wiring behind the kitchen cabinets and tap into the ground and run a new ground leg, which makes all of the lights work again. There must be either a separate ground circuit for those particular lights, or a break in the ground wire somewhere between them and the remaining clearance lights, as all of the others worked just fine??
โNov-04-2015 09:21 AM
โNov-04-2015 03:50 AM
โNov-03-2015 08:11 PM
โNov-03-2015 06:10 PM
โNov-03-2015 04:56 PM
