Cheeva316's avatar
Cheeva316
2004 Jayco new owner hot water heater issue help!!
My father just moved onto our property and we just bought him this 261 Jayco 5th wheel.
It has gas/electric water heater.
We filled the tanks, fired up the gas option water heater, the gas line fired up no problem, I went inside and felt the holding tank to get very got. When I turn the facet on or shower the water only got a little warm then back to cold. I went back to the holding tank and it still felt hot to the touch.
I figured that maybe there is a water flow issue or trick to get the 6 gallon water holding tank flowing through the plumbing.
I have read every manual possible and it only explains how to get yhe water heater going but nothing else.
I know in a house it's all self explanatory that you demand hot water and you get it.
I don't turn on the electric function of the water heater cause it trips the 30amp breaker or the a/c breaker.
I checked to make sure all the valves are open for flowing water.
Again when holding tank is hot to the touch I turn the hot water on and it's maybe very warm for maybe 30 seconds.
My father can't even take a shower in the rv and he's disabled and it's a mission getting him into my house to take one.
Any help is appreciated.
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
