- Or maybe look at adding a minisplit. Outdoor unit on the back bumper.
- Hondo99ExplorerThanks for all info! I may look @ Alliance they are one company now builds full time RVing units , whatever that means, I’ll stick it out but I planned on trading anyways , either end of year or spring ????
- Grit_dogTrailblazer^Sorry, maybe you missed that I was incorrect and corrected that your AC IS operating properly.
Guess it makes sense to find ya a 50amp camper with dual ACs and possibly one with better insulation if you’re going to continue living in it in extreme conditions.
I did look at a Grey Wolf a couple years ago when we were lookin for a toyhauler. And my opinion was that they were fine, but on the low end for bike quality and amenities.
But that’s a common challenge when using something meant for occasional use (camping) and not all weather, all conditions, all the time.
Good luck in your search.
I’m no expert which are the best or aren’t, in toyhaulers but we got us a 2017 Heartland Torque (in 2021) and it was pretty good quality. Only issues was a slow draining gray tank which I never diagnosed and the “levels” panel pooped out. The water levels quit working.
One thing to consider, maybe. One of the things that made toyhaulers preferable to us was the high ceilings and big open space.
Also a detriment to cooling (yes cool air sinks, but there’s a bigger volume of hot air up top compared to shorter campers. Maybe consider closing off the garage area with something temporary like a floor to ceiling canvas tarp or something. You’ll reduce the effective volume of space to cool? Just an idea. - Hondo99Explorer
Grit dog wrote:
I realize comprehension is low sometimes on this forum, as I’m the only one who apparently picked up on you saying your AC blowing 70deg air out of it.
So you’re trading in a trailer with a bad air conditioner for one with basically the same unless you go 50A dual AC but with a working AC?
Even if you don’t want to diagnose why your AC is putting out room temp air, if you can use basic hand tools and reconnect 3 wire nuts back to the same wires, you can fix your problem in about an hour just by buying a new AC.
And you can weather proof the stuff a bit for a bit more efficiency just like you’d want to with any RV. Especially if you’re trying to live in a gray sardine can in some of the hottest weather in the country.
This be like the guy who’s gonna spend $2700 for 70ah more battery capacity….why?
30 foot I know the insulation is little, the walls are hot ?? - Grit_dogTrailblazer@doug, yup 10-4. Makes sense.
Good to know there’s nothing wrong with the OPs AC other than his whole setup isn’t sufficient in extreme temperatures. - ktmrfsExplorer IIIheat gain (or loss) is dominated by wall area, not interior volume. And the greater the interior volume is the smaller the ratio of surface area to volume is.
Trailer has lots of surface area not much volume
Compared to a house, also add in the heat gain through the trailer floor. In a house ground temps is usually pretty constant around 50F no matter where in the country you are. In a trailer temp under the floor is close to outside ambient
Then factor in the window area vs. total area compared to a house.
Then add in the low R factor of trailer walls and windows.
All this adds up to lots of BTU needed to cool a small volume.
But then if you go buy a room AC unit for a house a 13K BTU AC unit is usually only claimed to cool a pretty small room, something similar to a TT but in a place with much higher expected insulating value and fewer windows.
So in a TT you need to be able to move lots of BTU to keep it cool even though the interior volume is small. All driven by physics and construction limitations
Same problem occurs trying to heat a trailer in cold weather. A 30K BTU furnace in my trailer will often barely keep the trailer warm near freezing while and 80K BTU home furnace keeps by 2600 sq ft house nice and toasty at 15F and cycles less than 50%. Grit dog wrote:
^I’ll defer to you as the expert here. I’m certainly not. Nor have I ever put a thermometer to one. And it always feels like the air coming out is far more than 20 deg cooler than ambient (in the camper of course)
Although apparently it is not. Must just feel that way when it’s 95deg out, camper is sitting in full sun, obviously isn’t keeping up with a thermostat setting in the low 70s but feels ice cold if you’re standing right underneath it.
I would have guessed more like 30-40 deg.
So basically there’s nothing wrong except for the OP having a normal (albeit marginal) setup for the extreme Summer heat and humidity in the Deep South.
Well then I agree, if that’s the plan, to cool the inside of a tuna fan in a sauna, go 50amp, dual AC and don’t look back.
Or try to find some shade for less money than the large amount of $ you’ll spend trading a Covid era purchased newer camper on a brand new more expensive one.
I spent years, sometimes working away from home for months at a time, but in the same location generally long enough to rent an apartment or old house with a couple guys on the job. As much as I thought a RV would be the ticket, it never penciled out.
The only way it would pencil out was if I would have had to hotel it. Then a RV would be a little cheaper.
Just something to think about.
Unlike a DASH AC system, the best you can get off a Roof AC system is around 52 to 58 degrees output. But not in very hot weather. Doug- StirCrazyModeratorsounds like the AC is working not too bad to me. over 95 out and the air coming out is 70, which means it's colder than that and warming up a bit in the roof system before it gets to the vent.
People expect house ac like performance from these little units, but the plain truth is the rv's are not insulated good enough to let them work well. sure, a lot of the walls are all block foam now which is decent, but the floors, ceilings, and windows are not and while they advertise them as R13 or whatever they probably actually perform as r2 or 3 at best. slides are even worse as there is a gap that is kept closed by two 1/8" chunks of rubber.
I have a large AC on a 39 foot 5th wheel and it won't keep the whole rv cool I have to sacrifice cooling to the front and rear bedrooms by opening the dump on the main unit, so all the cooling goes to the living area, then at night I close that and divert the cooling back to the sleeping areas. does it work that way barely... The better option would be if you are prewired for it is to add a second unit, this would mean you would need a 50-amp power setup if you want to run both at once though. still cheaper than trading in and buying the same issue. - Grit_dogTrailblazer^I’ll defer to you as the expert here. I’m certainly not. Nor have I ever put a thermometer to one. And it always feels like the air coming out is far more than 20 deg cooler than ambient (in the camper of course)
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
