- Kayteg1Explorer II$88 generator
60 LED solar for $29
Got new coupons today.
I have this (or its twin) generator in my camper - regardless build-in propane generator.
That thing can be lifted single-handed above the head and runs everything in my camper but AC.
Micro-oven, coffeemaker, charger.
Not the easiest to start, but what was bought as a back-up become primary.
I also use the lights in my garden and they add security, but the timer gives you max 1 minute and batteries don't last long.
I still like the light output and likely will hook up the light to my camper battery. - MEXICOWANDERERExplorerHarbor Fright used to be a great deal. Now they are merely ho-hum.
Diagonal squishing pliers. Squeeze until the wire gives up and separates due to fatigue.
Drill. Chucks made out of mild steel. The Jacobs style were sooooooo soft steel the Chinese gave up and starting making the chucks hand tighten. Oooooooo so good for galling drills.
Battery Chargers. They are all SMART chargers except their roll around shop charger which is a Solar brand and found cheaper elsewhere.
MARINE Heat Shrink Tubing Kit. This is a 3 to 1 shrink ratio kit with adhesive liner and it works excellently. Same for their BLACK CABLE TIES
Electrical Terminals. You must be joking. Off center ring terminal holes. Foil thick conductor. Plastic not vinyl insulation.
Hydraulics. A breeze to buy. As you are carrying the box out, the hydraulic oil leaks and before you know it you've slid/arrived at the trunk of your car.
Make wise choices of what you buy - coolbreeze01Explorer
Chuck_thehammer wrote:
I got the e-mail from HF, went out and purchased there powered trailer jack.
@ 25 percent OFF..
saving 35 dollars...
and I used a new old stock Ford starter solenoid and a used rocker switch to control it. and mounted solenoid and switch between the (2) 30 pound propane tanks. and fuse is inside the battery box.
then I opened the power jack and greased everything well.
Nice savings, just as the coupon was intended :C - Chuck_thehammerExplorerI got the e-mail from HF, went out and purchased there powered trailer jack.
@ 25 percent OFF..
then I opened the power jack and greased everything well. - BumpyroadExplorer
Kayteg1 wrote:
and where on the coupon you see a note
"only for marriages having different phone numbers" ?
OH, it doesn't have to be a spouse. it can be a child, nanny, etc. and if you are part of the 3% of the population that can't come up with two phone numbers, you can contribute to the moral decay of this country by using an imaginary number.
bumpy - camperguy99ExplorerCopied coupon and printed it (a little difficult!) and just used at Harbor Freight today the 24th. Yep, 25% off a $20 item and they gave me a free Voltmeter!
- KendallPExplorerI gotta' make another batch a' popcorn! You guys are freakin' hilarious!
Keep going! And maybe let's see if we can't divert some cancer research resources to this important issue!
{ =^ D - Kayteg1Explorer IIand where on the coupon you see a note
"only for marriages having different phone numbers" ? - BumpyroadExplorersince some folks evidently have limited reading comprehension, the coupon says, "limit, one coupon per customer per day". Thus it is completely within the rules for the husband to make a purchase and use one coupon. and the wife can also make a purchase and use one coupon. I "assume" that most folks have several phone numbers available.
bumpy - Kayteg1Explorer II
fj12ryder wrote:
Hmm, I must have missed the part where it said one coupon per telephone number per day. I thought it said one coupon per person per day. Ethical, smethical, as long as I can get that free $3 flashlight. :)
I guess it is just how a person was raised as to how they view things like this.
Sure it is. I go there with my wife.
I take one coupon and make one purchase, wife takes another coupon and when she gives the same phone number, she is refused honoring the coupon.
It is how they view the things.
Now reality question.
Do you think that even with 25 percent off, they don't make profit?
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
