brn2romethewest
Dec 31, 2016Explorer
5ver suspension replacements
Hello,
I will be replacing my suspension parts on the fifth wheel trailer within the next two weeks. Went to order parts and ran into a few questions that i need some answers (or maybe not).
Trailer description: 2005 K-Z Durango 275RK, 10,000 lbs max weight. Tandem axles, (AL-KO 5200 lbs axles) 33" center to center. It came with 15" wheels and i upgraded to 16" wheels with LT tires.
1. Measuring for the right size springs. What is best way to get measurement while mounted on trailer? Axles suspended in air with wheels off the ground or wheels on the ground and weight of trailer on axles?
2. The equalizer that is factory installed is an EQ-310. The dimensions are 6 1/16" wide, and 4" tall. Looking at the replacements with bushings built into them that absorb the bumps (Trail Air, Equaflex, flex flex flex etc.),there are none that match the current equalizer size. Is there any models that will work without changing the height? I do not want to lose anymore clearance.
3. If i was to change the equalizer size, wouldn't that change the size of the springs?
Thank you for the help,
Greg
Greg
