May-25-2022 03:55 PM
May-29-2022 10:48 PM
May-29-2022 03:42 PM
May-29-2022 09:23 AM
May-29-2022 09:21 AM
May-29-2022 07:22 AM
May-26-2022 08:41 AM
Dusty R wrote:
True, but I do have the proper tool. I'm a retired construction electrician. And if I remember right, a box is required when the voltage is above 35 volts. On a trailer a box collects road salt and rusts.
May-26-2022 08:30 AM
marpel wrote:
Thanks for all the replies:
Just to clarify though, the new cable was not too short as the new box was placed right beside the old box, so the, loosely strung, replacement cable appeared able to reach the old box quite easily.
And BB_TX, your description was exactly what I was planning on doing. Take photos or label current box layout and just repeat with new cable. Logically seemed pretty straightforward.
Just figured, because no-one seemed to want to tackle the junction box connection in any of the vids/tutes, that I was missing something that made it difficult.
Marv
May-26-2022 05:19 AM
May-26-2022 04:44 AM
Gdetrailer wrote:Dusty R wrote:
I would use crimp butt splicers and Heat Shrink insulation tubbing.
:R
Rookie mistake.
Crimps work best with proper quality crimping tool, very few people have the proper crimping tool and substitute pliers and crush the connection making a very poor and unreliable connection.
Additionally, standard heatshrink tubing is not weather proof or water tight and moisture will destroy the connections hidden inside the tubing.
Not to mention the average backyard electrician won't have a good heat gun and will use matches or a lighter to shrink the tubing making a mess of the job..
For heatshrink tubing to work in the outdoors you must get adheasive lined tubing, it has a heat activated glue that surrounds and seals around the wire insulation making a good water and weather tight seal..
But, a good electrician will try to avoid allowing connections to be exposed to weather which means taking the connections back to the original connection box which is protected from the weather.
Inside that box, the connections are made with wire nuts, no need to reinvent the wheel. Just use the existing wire nuts inside that box and all will be fine.
May-25-2022 08:34 PM
May-25-2022 08:27 PM
May-25-2022 07:35 PM
May-25-2022 05:21 PM
May-25-2022 05:14 PM
Fisherman wrote:
Maybe the new cable was too short for his application. More contacts and breaks, more corrosion possibilities and breakdowns. I would go with one junction box.
