Scottiemom's avatar
May 26, 2022
A/C Thermostat
I am having an issue with my thermostat. First off, my A/C is running exactly as it should as is my furnace. However, the thermostat is no long "true." To get the compressor to kick in, I have to push the thermostat slide all the way up to 85. It still cools to where I want it and it cycles on/off. However, I always kept it set in the 72-75 range and that no longer does anything. Same thing with heat. If I want it at 72, I have to slide it up to 85.
I know nothing about it and I do have a service I have used before when I get to my destination, but just wondered if this is something common. I talked to a tech here at the rally I am at and he seemed confused, so I decided not to let him do anything with it as it is working right now.
Dale
