- TbucketExplorerProblem solve. Thank you guys for the info
- Hornnumb2ExplorerI like to run my fan with the heat, my trailer only has one heater outlet. The fan running helps circulate it through out the trailer.
- NinerBikesExplorer
Tbucket wrote:
NinerBikes wrote:
Did you read the Dometic Owners Manual for the thermostat?
Shame on me. No sir I did not. That will help.
Then you've no more need for this non technical thread you started. :W
Frankly, I'd be more than a little embarrassed about it, and would have called the manufacturer for more instructions on it. Waste enough of their time answering the same question, over, and over and over, and they'll realize how poor the design is, and make something better. The squeaky wheel gets the grease. - Chris_BryantExplorer II
Tbucket wrote:
jetcare wrote:
If you have a newer style Dometic Thermostat, push the Mode button so that the FAN position is illuminated. Use the +/- buttons to move the fan to AUTO. Right now, you have it in the Low or High position.
Yes it is a domestic. I will try that and advice the results. Thank you.
Jetcare's instructions should work- this question is asked enough that it almost needs to be a sticky. Tbucket wrote:
I don't have auto mode. Only 3 functions.
Fan
Cool
Furnace
Correct, but when in FAN mode, you have the option of HI/LO/AUTO. Pick AUTO. Doug- TbucketExplorer
No heat pump. Just A/C it worked fine for the last 2 seasons, and I did read the owner manual on the A/C - TbucketExplorer
Shame on me. No sir I did not. That will help. - NinerBikesExplorerDid you read the Dometic Owners Manual for the thermostat?
- micpib1ExplorerWhat are the chances of you having a Heat Pump, not just an AC? JH
- TbucketExplorer
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
