Xatorisan
Nov 20, 2024Explorer
I remember your previous post about the issues with your solar setup! It's great that you got the new RENOGY Voyager controller. With the 100W panels, that controller should be fine. I’ve used a similar setup before, and the Voyager did a solid job handling everything. The flexible panel you mentioned can be a bit tricky with its power output, especially if it's offshore-made—sometimes they don’t perform quite like expected.
- way2rollNov 20, 2024Navigator II
While i am sure Qazert would appreciate the follow up, you are responding to a post that's 2 years old and they haven't been on here since. Also, reading through the thread it looks like the OP already solved/answered any questions they had.
Having RV issues? Connect with others who have been in your shoes.24,195 PostsLatest Activity: Feb 04, 2025
