Retired_Sailor's avatar
Jun 22, 2015
ABS (Antilock Brake System) light on after change batteries
I just replaced the chassis batteries on my coach and now the ABS light stays on when the engine is running (haven't driven it yet). I'm guessing this is a computer issue and I'm going to have to get the computer reset but wondering if anybody else has had this issue. Thanks
  • Thanks for the comments. As was suggested the light went off after a few miles. Appreciate the assist!
  • This is common with many of the ABS systems. All it knows right now is that the wheels haven't sent it any signals. Run it just a little and it will probably come out of panic mode. I haven't been in foundation brakes for a decade, but that was a problem.
    Matt
  • It most likely will go out when you drive it a bit. If there is a problem with your ABS, your brakes will still work okay but the anti-lock will not work.
  • I'd just try driving it 10-20 miles and see if the light goes out on it's own. The ABS computer might just reset once driven.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
