Denny___Jami
Jun 22, 2016Explorer
Just a guess but I'm thnking the icing is taking place at the change over valve because it's not completely changing from the heat to cool mode. Heat pumps shift back to the heat mode when turned off, the changeover valve is energized when the system calls for cool. If that's the case the valve would have to be replaced, I would replace the unit and I know how and have the equipment to replace it.
Denny
Denny
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
