xnizstudio
Aug 27, 2019Explorer
westernrvparkowner wrote:xnizstudio wrote:It isn't the breaker. The entire wiring is wrong. This isn't on the guy selling breakers, it is on whoever wired the breaker and wired the outlet.Ed_Gee wrote:kmb1966 wrote:
how can a 30 amp rv plug fit into a 220 outlet? I have never seen one that fits.
Lots of ignorance on this issue. Take a look at your 220V electric dryer outlet if you don't know how a 30A RV plug can fit into a 220 outlet.
Do you really think I’m stupid enough to force a plug into a socket that doesn’t fit ? I’m not that ignorant. It was an honest mistake that the guy sold me the wrong breaker
I was told by two different people I need a single pole 30amp breaker. Not a dual. It was wired up as of it was going to be set up for indoor appliances which is what the dual pole breakers are mainly used for. A single pole breaker should cut the voltage in half to 110v. The wire ran from the dual pole breaker directly to 30amp RV outlet . There may have been a way to wire the dual pole breaker to only put out 110v but it’s a bit too late now.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
