cannesdo
Jul 24, 2014Explorer
Adding 2nd tv in bedroom...Some questions...
36 fifth-wheel. I'm on Dish in the living room and have a Winegard Carryout (two incoming cables. Right now I'm just running them through the window but I'm going to try running through the outside connectors in the power cord compartment. Here are the connectors I have in the bedroom.
Looks a lot like the panel I have in the living room but there I also have an antenna coax connector. Don't know what the coax cable coming ot of the top is though. I included the end of that in the photo. Is one a direct connection to the living room and the others in the panel coming from the outside connectors?
My guess is there is a splitter somewhere after the power cord compartment that sends the signal to both the bedroom and the living room? So if I want Dish in the bedroom I need a 2nd receiver in there? I have a 2nd remote that came with the living room receiver. I am the only person in the rig, so no one will ever be watching one thing in one room and another in the other and I would prefer the operate the bedroom tv independently of the other (which I think means another receiver).
I'm not even sure both the connectors in the outside compartment are working. If they aren't is there a way I can still use Dish in the bedroom by working off the receiver and remote in the living room?
Going to check my owner's manual as well to see if I can figure out how the coax is wired. Just thought someone might know based on the information I have so far.
And any input on flat-screen design as far as traveling? At first I thought the ones with a single post might be a bad choice as the "bobble" but that might actually be an advantage so the screen would give with the motion of the trailer. The bed closed up right under the lip of that shelf so I could also travel with the tv lying flat on the bed.
