ulvik's avatar
ulvik
Adjusting slide-out on Rockwood TT
Hello guys and gals! Been on a vacation for the past two months and recently noticed if towing in the rain some water always seemed to creep on the inside of the trailer. Today I noticed the slideout on the drivers side of our Rockwood 2304DS was out of line I guess you would say. The front of the slideout sits flush when closed but the other end of the slidout towards the rear sticks out about 3/4 of an inch and it is not creating a tight seal when closed. The slideout is a two beam system I guess! It is the one with two main beams at the bottom with a stationary gear on each side to move it in and out. My question is how do I adjust it so both sides sit flush when closed to keep water out. Did a search here and could not find an answer and even looked on YouTube. Any advice would be great. Currently up in Ohio and would like to get it corrected before we get back on the road. Thanks in advance for your help.
  • Thanks I will take a look and see what I can find out. Thanks!
  • Go to Lippert's website. They have manuals for their products including slides. There are instructions on how to adjust them which I've referred to when my slide needed adjusting. You'll need a large adjustable wrench, top. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
