deepdoc1
Aug 20, 2016Explorer
Air Conditioner Thermostat question
Well, my 10 year old Duo-Therm compressor bound up, so I need to replace the AC unit. I have the 13.5k AC with heat strip, 5-button CCC thermostat, ducted, single zone, and the propane furnace is controlled by thermostat; probably the standard setup for the 32' rig.
I do like the AC when it works, and we do enough cool/cold weather camping that a heat pump would not be a bad thing, so I plan to replace the unit with a Penguin 15k heat pump. I'm trying to educate myself on thermostats and other AC related things, so here's a couple of questions. My tank area is heated by the furnace, and the heat pump will not do the basement area, but I would be using the propane furnace anyway at temps low enough to be a problem since the heat pump is not as effective (or so I understand) at low temps.
1. I know the new AC's need an adapter board to work with the 5-button thermostat. Will upgrading the stat to the 12-button model give me added functionality, or is it just more "shiney"? I'm thinking of outside temp sensor, larger display, etc.
2. When plugged in to shore power or generator, can the thermostat be set up like my home unit to run on heat pump until it won't heat enough then automatically use the propane furnace (similar to Emergency Heat mode)?
3. When dry camping, can the thermostat be used to just control the furnace?
4. Do both the 5-button and 12-button have essentially the same functionality in a one-zone setup? I'm not sure of the usefulness of the program-ability of the 12-button; has anyone used it, or have thoughts on it?
Please feel free to chime in with ideas, lessons learned, etc. Thanks!
