- Dusty_RExplorerMaybe a "O-ring" like a garden hose gasket.
- surgtech56Explorer
mobeewan wrote:
Is the leak between the fitting and tank or the threads where the drain valve screws into the tank?
Is the fitting cracked and leaking from the threads?
It looks like both. I thought it was just from the threads but it looks like it’s also leaking between the fitting and the tank. I was going to put a hose clamp on the threads . - mobeewanExplorerIs the leak between the fitting and tank or the threads where the drain valve screws into the tank?
Is the fitting cracked and leaking from the threads? - surgtech56Explorer
Sorry blurry, it’s been raining. There’s. A leak around this outlet. Any adhesive that will hold s a quick fix? Thank you - MFLNomad IIgoogle rv.net photo posting: just follow Barneys instructions.
Jerry - FishermanExplorer
surgtech56 wrote:
How do I add a photo?
Look at the top of the page in red, there's link to the forum photo posting. https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/15775751.cfm - surgtech56ExplorerHow do I add a photo?
- MFLNomad IIYou might give a little better description of the leak. Is it the actual water tank leaking, or maybe just a hose fitting, from the water inlet? A picture would help, if you can see where the leak is.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
