solismaris
Sep 19, 2013Explorer
Tom_M wrote:
If the crank assembly and support arms are intact you can replace just the head unit. It's hard to beat the Winegard Sensar IV for all-around reception. If you will be in areas that don't have any VHF channels the King Controls Jack is a cheap alternative. If you need to replace the crank mechanism stick with the Winegard.
Great news! It looks like the crank and arms are ok so I should be able to get a replacement head (with the UHF enhance assembly). Should be better then before!
I didn't know they were still using VHF for tv channels.
Great news because it costs 1/2 as much as an all new antenna, and I don't have any roof patching to do!
