RoyB
Sep 19, 2013Explorer II
If you want to keep the BATWING antenna then all you need to do is purchase a new BATWING with UHF add-on assy, It will mount to your existing crank-up assy with two pins. Takes all of five minutes to mount.
Just make sure the new BATWING antenna has the UHF dipoles added. The older batwing antennas did not have the UHF dipoles added.
I would also inspect the existing RG cable real good to make sure the F-TYPE screw on connector has not been damaged.
Roy ken
Roy ken
