Tom_M wrote:
BFL13 wrote:
Another thing is if you have one of those coax amplifiers, you can't use it with the antenna amplifier and amp the amp. Doesn't work at all. Your antenna amp is all you can get.
You can not place an amp between the antenna and the power injector (usually the wall plate). It can be placed after the power injector. Just be aware that too much amplification can cause problems. If you are close to the transmitter sites you can overload the tuner in the TV. This will not harm the TV, but you may not be able watch some channels.
Thanks. I would like to try that again only doing it right.(Or at least with a chance for it to work "depending") Can you please clarify how to place things? The above is a bit confusing (to me)
ISTR I was putting the coax amplifier (on inverter power same as the TV) on the coax into the TV set, with the antenna head amplifier already powered.
In the stick house on cable, this coax amplifier I have does amplify (after too many splitters) with analog when we had that. It seems to cut off signal with digital using a newer cable box. Not sure just what is the trouble there.
Of course I want to try the double amplification in the trailer with digital OTA. (Which the Jack does ok, but I would like to get stations farther away--60 to 70 miles)
--Merry Christmas everybody!
