rjsurfer's avatar
rjsurfer
Anyone ever change out slideout motor?
My Lipert through frame slideout has a intermittent motor and it needs to be changed. I found the exact replacement on EBay but I can't get a handle on how its mounted at the end of the slide drive screw.
It appears that its just attached at the end of the lead screw and uses this physical connection to hold it in place, and the frame keeps it from turning. Sort of like the mounting of the front jack motor.
Lipert was no help.
Thanks
Ron W.
1 Reply
  • If just the motor, you remove 1 or 2 (depends on the LCI style) 9/16 bolts that hold the motor and the motor just pulls loose. IF you purchased the complete telescoping assbly you remove the 2 bolts that hole the motor end and remove the 3 large nuts on the end threaded and pull it out. Doug
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
