NatParkJunkie
Sep 30, 2020Explorer III
you can check how you're leveled when dumping too. I have a truck camper, and the drain pipes come out the side of the waste tanks, not the bottom. I've found if the dump station isn't very level, if I am nose down, that the gray tank in particular will not drain all of the water out of the tank. I need to either turn around or pull up on leveling blocks to get the front end raised up so that all the water can actually drain out.
