Hurricaner
Sep 30, 2020Explorer
Winnebago uses non contact tank sensors and they're usually pretty accurate. You have a 42 gallon grey tank and it probably takes a lot longer than 20 seconds to empty, more like 2 or 3 minute's. Next time you dump look at the hose and make sure the tank has actually stopped draining. The other possibility that was mentioned earlier is some nut left one of the install cutouts in the tank and it is blocking the drain.
Sam
Sam
