wopachop
May 15, 2019Explorer
Are these 12v parallel batteries wired incorrectly?
These 12v batteries came with the trailer. Theyre mismatched and you can see the 2nd battery has more corrosion. Is that due to where the solar and ground wires are attached to the pair?
The batteries only lasted 1.5 years and spent most of their life in storage with solar charging them everyday. They trigger low voltage alarm just turning on the faucet.
The solar pos and neg were attached to the second battery.(top in picture)
Is this an unbalanced way to wire two 12v in parallel? Or does it not matter which battery gets grounded to the frame?
