pnichols
Jun 20, 2015Explorer II
path1 wrote:
Is that correct or is it depending on what charger I have in RV? Or maybe what type of battery charger (running from generator) I'll be using? I don't even know if charging directly from charger is always better or sometimes or usually, or even better at all.
Just to be precise .... it also depends upon the type of batteries you're talking about.
Since you didn't say, all the comments above were probably based on an assumption that you meant wet cell RV batteries. Some of the responses might be different it you had certain types of dry batteries in your RV.
