- DAWg134Explorer
Sam Spade wrote:
Another potential downside is that you may not have ANY magnetic material in the shell of your RV. Mine is all aluminum and fiberglass except for the front fenders and the bumpers.
Yeah, in that case you'd have to attach some steel discs to your RV's shell, using VHB tape or simply screwing them in place. Alternatively, in the past I've also attached my panels by placing additional magnets on the inside of the windshield. That actually worked well, but proved to be unnecessary as placement of the panel on the hood was more than adequate to keep the batteries charged, even during periods of sustained inclement weather.
Since the magnets on the panel would automatically be attracted to the steel plates, the size of the plates wouldn't have to be very large - 1-inch diameter ought to be sufficient. If that wasn't inconspicuous enough, the plates could be painted to match the RV's exterior. Placement of the metal discs is easy enough - just place them on the panel's magnets, remove the backing from the VHB, then hang the panel on the selected surface(s) of the RV.
As far as procuring circular plates, steel washers would work just fine. For something without a hole in the middle, you could saw off the appropriate thickness of round steel bar stock or simply Google "steel circular plates" for numerous pre-fabricated discs of various sizes.
If none of those approaches suit you, try contacting Mexicowanderer and see whether he might be willing to sell you a few of his aluminum magnets. :W - MEXICOWANDERERExplorerBetcha my aluminum magnet would work. Heck it sticks to my Transparent Aluminum windows!
- Sam_SpadeExplorer
DAWg134 wrote:
The only downside is that you may have to periodically clean off an inexplicable accumulation of iron particles from the magnet .........
Another potential downside is that you may not have ANY magnetic material in the shell of your RV. Mine is all aluminum and fiberglass except for the front fenders and the bumpers. - DAWg134ExplorerI attach my temporary-mount solar panels to the RV using powerful neodymium magnets. Simply use 3M VHB tape to permanently attach the magnets to the panel, then use another piece of VHB tape to mount a piece of thin rubber to the opposite side of the magnet. This allows you to attach the solar panel directly to the body as well as on top of the cover without marring the paint. I attach one solar panel on the hood, facing west, and a second identical panel on the side of the RV, facing south.
The number of magnets required will depend upon the weight of your panel(s) and the type of magnet you select. I use six 1" diameter x 1/4" thick N42 disc magnets I purchased online from K&J Magnetics. I see that they now carry N52 magnets as well.
N52 Magnets are $7.70 apiece, but each one is capable of "lifting" 33 pounds axially.
The only downside is that you may have to periodically clean off an inexplicable accumulation of iron particles from the magnet to prevent them from rusting and discoloring either your cover or the vehicle's paint. Apparently, there is an infinitesimal amount of iron suspended in the air - possibly from brake discs or drums. - wa8yxmExplorer IIIIf you can park the trailer facing south, Mount the solar panels on the tong, (Not under the cover) NOTE: make sure the mount is secure so they do not grow legs.. Be sure to use a proper charge controller as well..
When you go on the road, you can use other options
Can't park facing south.. Well park the solar panels on the rear, again make sure they are very securly attached. Or you can pole mount 'em if the facility allows. If you have a long term slot, use a socketd pole (IE: Look at Sunsetter flagpoles for what I'm talking about) you can take the pole with you and fly the flag come July 4. - wilanddijExplorerDisconnect the batts when the RV is covered. House batts will totally disconnect using the switch. Chassis battery needs to be physically disconnected to avoid rundown by parasitic draws. Most physical battery disconnets can be easily installed into the ground side of the battery.
- MEXICOWANDERERExplorerExtremely high tech solution. Place honorable door mat between roof and cover. When the cover comes off so does the panel. And the power wire. And the cable tie mounting clips. White Velcro swatches looks bad on a rolled up cover? Covers last ten years? Velcro is expensive? Or is it for aesthetics a little redwood house with shingles for the panel? In an RV storage lot.
BTW Camarillo, California must then equal say Mt Washinton, New Hampshire, for high wind?
Somebody be beucoup unclear on the concept... - Nicholsfamily05Explorer
MEXICOWANDERER wrote:
"and make a single stake or double stack that goes into the ground and attach it there"
Unfortunately in many cases...
Be sure to affix a comfortable high-speed handle on it...
Apparently mexicowanderer isn't capable at building something that requires a little bit of skill just slap it together with tape, And Velcro.
Let's no try to make it look like we care about our rigs in the off season as well as when in use.
Covers are expensive why attach something to it to wear it out faster, or to have the unit bang around in the wind and damage something.
But to each his own. Just a suggestion - AlmotExplorer IIIAttaching to cover? What cover? There is hardly anything that adheres well to Poly tarp. Besides, the tarp itself (and most cheap "covers") don't last long in heavy winds. Attaching anything to it will create stress points and it will last shorter yet.
When I needed to attach a small trickle charger - 2.5W panel - to my truck covered with tarp, I tied it to antenna. Had to make a hole for antenna anyway. It's not about keeping vehicle totally protected from humidity - tarp only has to protect from direct sun and shed "some" rain water off. Stake in the ground would work, though depending on location it might be safer to keep it somewhere high. - MEXICOWANDERERExplorer"and make a single stake or double stack that goes into the ground and attach it there"
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 16, 2025
